My Cisco 851W does not support Dot1Q !!
Sep 15th, 2007
Hi Friends
My Cisco 851W does not support Dot1Q on its Fastethernet interfaces :
I mean these commands are not accepted by Cisco 851W :
interface fa0.1
encapsulation Dot1Q
I need this in order to route between my Vlan (Wifi and non WIFI Vlan) as indicated in the Cisco official guide document
so what is wrong ?
please help me urgent
scottmac Sun, 09/16/2007 - 05:00
  • Green, 3000 points or more
Do you have an IP address on the fa0 port?
If you are going to use dot1q, the primary / physical interface doesn't get an address, only the subinterfaces.
Posting your (sanitized) config would be a great help ....
Scott
nkila_lna Tue, 09/18/2007 - 07:50
hi friends,
my config in 851w router:
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.2.1
ip dhcp excluded-address 10.0.3.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool sdm-pool2
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
ip dhcp pool sdm-pool3
network 10.0.3.0 255.255.255.0
default-router 10.0.3.1
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name boomerangpharma.com
bridge irb
interface FastEthernet0
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Dot11Radio0
description Cisco Open
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
broadcast-key vlan 3 change 10
broadcast-key vlan 2 change 10
encryption vlan 3 key 1 size 40bit 0 1234567890 transmit-key
encryption vlan 3 mode wep mandatory
ssid atmdata
vlan 1
authentication open
ssid atmvlan2
vlan 2
authentication open
ssid atmvlan3
vlan 3
authentication open
authentication network-eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
channel 2462
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
description intvlan1
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description intbvI1
ip address 10.0.0.1 255.255.255.0
ip virtual-reassembly
interface BVI2
ip address 10.0.2.1 255.255.255.0
interface BVI3
ip address 10.0.3.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.222
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
regards
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
