SSLVPN 1.1.4.176 and VPN3030
Sep 16th, 2007
I installed sslclient-win-1.1.4.176-anyconnect.pkg successfully on VPN3030.
WinXP can be connected in SSLVPN with IE7, but with Firefox 2.0.0.6 that does not function. Why?
With sslclient-win-1.1.3.173.pkg, Firefox and IE are OK.
amritpatek Fri, 09/21/2007 - 06:50
  • Silver, 250 points or more
SSL vpn does works on firefox. You need to check the settings on Firefox. Make sure all the settings are at their default values, clear all cookies and then try again.
adonnat Sat, 09/22/2007 - 10:24
No, it is not that.
I believe that there is a problem (VPN SSL 1.1.4) with the virtual machine JAVA (1.5 or 1.6), not used with IE (because ActiveX) but essential with Firefox.
VPN SSL 1.1.3 have no problem with the virtual machine JAVA (1.5 or 1.6).
dozinov01 Mon, 01/14/2008 - 16:55
I am also experiencing the same issue with Firefox and version sslclient-win-1.1.4.177
Anyone else? Is there a fix?
adonnat Tue, 01/15/2008 - 01:28
With anyconnect-win-2.1.0148-k9.pkg, no problem !
