Cisco 2514 Blocking DNS IP Question
Sep 16th, 2007
Hello Everyone,
I have a Cisco 2514 that is using NAT
from Ethernet1 to Forward traffic to
Ethernet0 (my cable modem).
Ethernet0 obtain's it's IP via DHCP.
It also grabs the Nameservers from there.
My question is, the only way I can DNS
working is to use OpenDNS numbers which
are different from the name-servers my IP
assigns.
I can't ping my DNS servers from my Router
or connection, but I can from a SSH connection
outside my network.
Is there some way my router is blocking traffic
to these servers?
Thanks in advance for any help that could
be provided.
Have a great day!
-Chris Barger
Richard Burts Sun, 09/16/2007 - 10:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
It is possible that your router is blocking traffic to those DNS servers. You provided some helpful information but not enough for us to find the problem yet.
One of the possible issues could be an issue with routing on the router to outside destinations, or it could be an issue with the way that NAT is configured, or it could be that there is an access list on one of the interfaces of the router. Or it might be possibly an issue with the configuration of the default gateway on the PCs on your inside connection.
A good place to start is with the question of whether you can access resources in the Internet by IP address if you can not get to the DNS server to resolve the name? For example the IP address of www.cisco.com is 198.133.219.25. If you put that address into your browser do you get to cisco.com?
It would also be helpful if you would post the configuration of your router.
Rick
