check a port for errors
Answered Question
Sep 16th, 2007
hi
howto check a port from Catalyst WS-C3550-12T for errors ?
kind regards
piotr
Correct Answer by JORGE RODRIGUEZ about 9 years 9 months ago
Piotr, from cli issue " show interface "
if you are particularly looking for specific interface issue "show interface fastethernet0/#" where # is the port number.
the "show interface fastethernet0/3"
will show interface stats for port 3, look for input errors, CRC, Runts, Giants statistics as these are indicators of communications errors between the port and the connected system. Same principle applies for gigabit interfaces if you have any uplinks. " show interface gigabitethernet0/#.
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sun, 09/16/2007 - 14:58
  • Green, 3000 points or more
Jorge
