Cisco2811 with ADSL
Answered Question
Sep 16th, 2007
  • Bronze, 100 points or more
I have Cisco 2811 router with WIC-1ADSL card, when i issue show diag, i can't see the card at the installed slot. So, i upgraded the IOS to one that supports ADSL, after that when i issue the show diag i see the following:
WIC Slot 1:
E1 Drop&Insert & G.703 (2 port) WAN daughter card
Unknown EEPROM ver 67
EEPROM format version 67
EEPROM contents (hex):
0x20: 43 30 00 00 05 C1 4F 43 33 39 53 50 81 00 00 04
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Is it hardware failure at the card? or what?
Thanks in advance
Abd Alqader
Correct Answer by paolo bevilacqua about 9 years 8 months ago
Yes, it seems at minimum the eeprom got corrupted. The card should be replaced.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 09/16/2007 - 13:38
  • Hall of Fame,
    Founding Member
