switch hw failure not in the logs
jorge.s
I've a question.
I'm having a Cisco Switch, CAT2950, nothing new, but where I have a fan issue, but I only realized about that once I seen the orange red on the status led of the Switch. Checking on the log's, via telnet, I don't find the problem anywhere, is like there is no issue at all, but once I get connected with console cable, I do see a error message of the fan failure. Is there a way to activate those servers to be coming also into log and syslog?
~Jorge
Richard Burts
Jorge
It may be that the logging level on the console is at one level and does include the error message about the fan and that the logging level sent to syslog is different and does not include these messages. Can you post the parts of the config of the switch that specify logging? It might also be helpful if you would post the first section of output of show log (done from the console) and these lines will generally describe the logging destinations and logging levels.
Rick
Rick
pe10015# sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes,
0 overruns)
Console logging: level debugging, 129 messages logged
Monitor logging: level notifications, 0 messages logged
Buffer logging: level notifications, 6 messages logged
Exception Logging: size (4096 bytes)
File logging: disabled
Trap logging: level warnings, 69 message lines logged
Logging to 10.56.1.195, 69 message lines logged
Log Buffer (50000 bytes):
Sep 15 18:14:59: %SYS-5-CONFIG_I: Configured from console by ioswrite on vty1 (1
0.61.177.100)
Sep 15 18:31:23: %SYS-5-CONFIG_I: Configured from console by ioswrite on vty0 (1
0.56.1.195)
Sep 15 19:41:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7
, changed state to down
Sep 15 19:41:19: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to dow
n
Jorge
Thank you for posting the additional information. As I guessed there are differences in the logging level. On the console the logging level is set to debugging (level 7) and it gets all messages (Console logging: level debugging). The logging level for Buffered logging is notifications (level 5) and so it would not see any messages of level 6 or 7 (Buffer logging: level notifications). And the logging level for syslog is warning (level 4) and so it would not see any messages of level 5, or 6, or 7 (Trap logging: level warnings). I do not know what the severity level was for the message about the fan failure. If you post the exact message then we might be able to figure out its severity level.
Rick
Rick
