Multicast Routing
Sep 16th, 2007
I have two network entities which have multicast routing configured and working on both them. They have a link between both of them that is currently not enabled for multicast routing thus keeping the two multicast domains completely separate.
At this point I need to have multicast routing working between the both, but only on one specific address (239.0.1.2). Rather then just adding an ip pim dense-mode (sparse-mode,etc) statement to the interfaces and then routing all of the multicast addresses is there a way to route that one address between the two?
Richard Burts Sun, 09/16/2007 - 17:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Michael
I am not aware of a way to route the multicast between the two without enabling PIM (sparse, dense, sparsedense whichever). My suggestion would be to enable PIM (whichever mode you like) and then to apply an access list on the interfaces of this link. The access list would:
permit ip host 239.0.1.2 any
deny ip 224.0.0.0 15.255.255.255 any
permit ip any any
This will have the effect of allowing your desired multicast, denying any other multicast, and permitting all other IP. Of course if you have an existing access list on these interfaces then this logic needs to be incorporated into the existing logic.
Rick
Kevin Dorrell Sun, 09/16/2007 - 23:21
  • Green, 3000 points or more
I think you will also need to allow any multicasts that your routing protocols need. (Or will those bypass the access list?) Typically it should be safe to permit ip 224.0.0.0 0.0.0.255. At the minimum you will need permit ip host 224.0.0.13 to allow the PIM, plus perhaps .27 and .28 if you are running sparse-mode.
Kevin Dorrell
Luxembourg
cjnwodo Mon, 09/17/2007 - 08:17
Sounds to me like you need to enable PIM on the interface and then apply a multicast boundary to it.
access-list 10 permit host 239.0.1.2
int f0/0
ip multicast boundary 10
Depending on the version of IOS you are using you might need to specify the direction of the multicast boundary in or out.
mhurley131 Fri, 09/21/2007 - 18:03
Quick question on the multicast boundary command...
Is the access list for multicast addresses that i want to cross the boundary or for addresses that i want stopped? The documentation ive found on the command is not very clear on that.
Based on the comment here it looks like i allow only the addresses i want, but the cisco documentation make it seem like you allow the addresses you want filtered.
cjnwodo Mon, 09/24/2007 - 00:17
In my experience i've used it to permit the multicast groups that I want allowed.
Note: If you use it on an IOS that does not specify the direction [ip multicast boundary 10 in or ip multicast boundary 10 out] then the command is bidirectional.
Pavel Bykov Mon, 09/24/2007 - 03:01
  • Silver, 250 points or more
Theoretically, MSDP was built for exactly your scenario. You can interconnect your multicast domains and allow only needed multicast group (e.g. using "msdp sa-filter")
Please refer to the following documents:
http://www.ciscotaccc.com/kaidara-advisor/iprout/showcase?case=K19073895
http://www.cisco.com/en/US/customer/tech/tk828/technologies_design_guide_chapter09186a00800d9d4c.html
Hope this helps
