Serial interface quiery
Sep 16th, 2007
I have a dout regarding the output of serial interface.Below output ...Its mentioned Availiable Bandwidth 88 Kbps.What does this exactly means.Is it some thing related to T1/E1 max bandwidth which an interface can use. ...Please help me regarding this
Output queue: 0/1000/64/90 (size/max total/threshold/drops)
Conversations 0/245/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 88 kilobits/sec
5 minute input rate 156000 bits/sec, 56 packets/sec
5 minute output rate 52000 bits/sec, 51 packets/sec
CSCO10758684 Mon, 09/17/2007 - 22:31
Thanks for your update ...I think CIR is comming in Frame relay concept..I ve changed Availiable bandwith using the command Max-reserved-Bandwodth 100 % but ..the changes i observed is from 88 Kbps it went to 648Kbps ...still didint understand ...the same ...Can some one help me
