IPCCX-CRS:CCDR Reports
Sep 16th, 2007
We are running IPCCX with 4.0.
I need a clarification Regarding The Report:"Detailed Call by Call CCDR Report".In which three Calls (from same caller ID)are sent to three different agents with same Node/SessionID/Seq.No and the same Start/End time. How is it possible!!!!!
Can some one clarify on this... and also session ID will be common for particular call or it will be different??
Pls. help me out!!!
bwilmoth Fri, 09/21/2007 - 06:55
The calls may not be duplicates. They can be a conference calls. which have the same SessionID, Session Sequence Number, but different talk time because different agents participated in the same call. (TheDetailed Call, CSQ, Agent Report shows the names of agents who participated in a conference call.)
Another possibility for the duplication that could be explored. Call is sent to one agent, but agent does not answer, so call is sent to second agent (explains zero talk time on one agent).
