Vlan information process?
paul.matthews Mon, 09/17/2007 - 00:52
Your question is rather vague, so I will simply suggest you look up VTP.
Paul.
goodnightjones Tue, 09/18/2007 - 00:42
correct me if im wrong but the tagging information is injected into the frame at the start of the trunk and removed at the end. This allows multiple vlans to communicate over multiple switches
rgds
gnj
paul.matthews Tue, 09/18/2007 - 01:23
The question is vague - so your comment is also valid, though by the use of the word "tag" you are specifically talking about .1q and excluding ISL.
If the question was about communication of existence of VLANs, VTP is the anser. If the question was about the tarnsfer of traffic over a trunk link such that traffic could be identified against a VLAN tagging and encapsulation are relevant.
Thanks for the information. But in Show VTP status, do i know what is the purpose of "MD5 digest: " and how to read this.
heres the ex:
Switch#sh vtp status
VTP Version : 2
Configuration Revision : 6
Maximum VLANs supported locally : 250
Number of existing VLANs : 8
VTP Operating Mode : Server
VTP Domain Name : home-oofice
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xD8 0xD8 0x38 0x22 0x98 0xE3 0xAC 0x65
Configuration last modified by 0.0.0.0 at 0-3-28-99 01:24:88
Local updater ID is 0.0.0.0 (no valid interface found)
