Copy a saved backup to pix?
Sep 16th, 2007
I save a copy of our Pix firewalls config to a tftp server every week, how can I restore a backup onto a Pix, I know have to save but not restore?
a.alekseev Mon, 09/17/2007 - 00:44
It depends on what PIX OS version do you have.
for example on 7.0 and higher
ASA5510# copy tftp: ?
cache: Copy to cache: file system
disk0: Copy to disk0: file system
disk1: Copy to disk1: file system
flash: Copy to flash: file system
running-config Update (merge with) current system configuration
startup-config Copy to startup configuration
system: Copy to system: file system
mkkeyan Mon, 09/17/2007 - 04:23
PIX(config)#configure ?
onfigure mode commands/options:
WORD Configure from HTTP:
Place IPv6 address within square brackets if a port is
factory-default Configure from factory-default
memory Configure from memory
net Configure from tftp
