Issue with WS-X6548-GE-TX
Sep 16th, 2007
I have problem with this module on my 6506 chassi,the 6506 doesen't recognize WS-X6548-GE-TX.the sup on this chassi is WS-X6K-SUP2-2GE and other modules are:
slot1: WS-X6K-SUP2-2GE
slot2: Empty
slot3: WS-X6516-GBIC
slot4: WS-X6516-GBIC
slot5: WS-X6548-GE-TX
slot6: WS-X6548-GE-TX
with 2 power 1800W
IOS: C6MSFC2-BOOT-MZ.121-13.E12.BIN
Jon Marshall Mon, 09/17/2007 - 00:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you send the output of a "sh module".
Jon
Jon Marshall Mon, 09/17/2007 - 00:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You should be able to run this command from enable mode.
if it's not available on the MSFC log onto the switch and run it. Are you running in Hybrid mode ie. IOS on MSFC and CatOS on switch ?
Jon
y.heidary Mon, 09/17/2007 - 01:18
i cant map that boot-version by the related IOS
lgijssel Mon, 09/17/2007 - 01:29
  • Red, 2250 points or more
Can you post the complete output of "sh version"? The IOS version is in there as well.
Leo
y.heidary Mon, 09/17/2007 - 02:13
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL0805TSRY
3 16 SFM-capable 16 port 1000mb GBIC WS-X6516-GBIC SAL0716C6HU
4 16 SFM-capable 16 port 1000mb GBIC WS-X6516-GBIC SAL0733JQ4N
5 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL0739M4VN
6 48 unknown FRU type (major = 24579, minor WS-X6548-GE-TX SAL1115L9W1
Mod MAC addresses Hw Fw Sw Status
1 0006.d65d.e23c to 0006.d65d.e23d 5.0 6.1(3) 6.2(2.113) Ok
3 000b.5ff9.c340 to 000b.5ff9.c34f 5.3 6.3(1) 6.2(2.113) Ok
4 000d.65f6.f63c to 000d.65f6.f64b 5.5 6.3(1) 6.2(2.113) Ok
5 000d.bc3b.aac0 to 000d.bc3b.aacf 2.5 6.3(1) 6.2(2.113) Ok
6 001b.0cd5.c268 to 001b.0cd5.c297 11.1 Unknown Unknown Other
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAL0806U2V6 3.4 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0804T6YN 2.6 Ok
#sh version
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(8b)E18, EARLY DEPL
OYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 13-Jan-04 11:33 by dchih
Image text-base: 0x40008980, data-base: 0x41878000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTFLASH: c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(8b)E18, EARLY DE
PLOYMENT RELEASE SOFTWARE (fc1)
Router-1 uptime is 3 days, 17 hours, 24 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "bootflash:c6sup22-jk2sv-mz.121-8b.E18.bin"
cisco Catalyst 6000 (R7000) processor with 112640K/18432K bytes of memory.
Processor board ID SAL0804T6YN
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
48 Ethernet/IEEE 802.3 interface(s)
18 Virtual Ethernet/IEEE 802.3 interface(s)
50 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
lgijssel Mon, 09/17/2007 - 03:11
OK, the IOS version is shown here:
This explains your problem, you will have to upgrade the IOS to a newer version.
Recommended is 12.1(26)E1.
regards,
Leo
y.heidary Mon, 09/17/2007 - 03:20
Thank you for your time & response, I will upgrade the IOS and let you Know the results.
Jon Marshall Mon, 09/17/2007 - 04:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I'm not sure it is your IOS that needs upgrading. Could you confirm if you are running in hybrid mode because from the output above it looks like you are running CatOS v 6.2 on your supervisor.
In which case, referring back to Leo's link, you need CatOs 7.6(1) as a minimum to support the WS-X6548-GE-TX module.
Jon
