How to setup 1841 To VPN Please
Sep 17th, 2007
I would like to know how to setup 1841 cisco router to VPN.I did setup the router but I'm unable to access any network resources when connected to the VPN.I'm only able to get to the router via loopback interface.
advise please
spremkumar Tue, 09/18/2007 - 03:43
  • Red, 2250 points or more
hi
can you post the config here ?
regds
spremkumar Tue, 09/18/2007 - 20:02
hi
are you able to connect with your vpn clients ?
are they getting authenticated and recieving ip address ?
are you seeing any error message when they are trying to get connected ?
regds
assyrian1981 Tue, 09/18/2007 - 23:08
Thanks for the reply
I connect successfully via cisco vpn client and i'm getting an ip address in the range of 192.168.1.X which is assigned to the vpn users.Refer to the config attached previously.
However i can't ping the 192.168.0.1 which is the gateway for the vpn clients.
No other error messages.
Please advise.
