Pix not booting
Sep 17th, 2007
My PIX 515E is not booting. It gets stuck. Below is the display after which it gets stuck. Pls help if it's a know issue to anyone.
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
32 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
Sarab
whisperwind Mon, 09/17/2007 - 06:03
Sarab what does the CLI show you after this happens? I have seen times when a device hangs and goes into boot mode, which when i type load or reload - i forget actual command, just use the help feature it restarts fine.
Not sure why or how this happens but for me its usually a transient issue, give that a try perhaps it will be the same for you.
iqresource Mon, 09/17/2007 - 06:13
Tnx dude. problem resolved. Bad CMOS battery wasn't allowing pix to boot.
justin.jocewicz Tue, 08/26/2008 - 15:43
You need to replace your CMOS battery and it will boot. You can then fix your time once it boots. Thanks.
Justin
