Rob Huffman Mon, 09/17/2007 - 05:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rommel,
show call history voice - Displays the call history table for voice calls.
To specify call detail record (CDR) storage time, use the dial-control-mib command, which has two sets of keyword and argument options. The max-size number option specifies the maximum size of the CDR event table. The valid range is from 0-500, and the default is 50. Setting the value to 0 disables the CDR feature.
The retain-timer number option specifies the length of time in minutes that entries will remain in the call history table. The valid range is from 0-2147483647 minutes, and the default is 15. Setting the value to 0 prevents any call history from being retained.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad861.html
Call Activity Monitoring and Call History Logging
The Cisco Unified CME GUI provides call history table information so that a network administrator can monitor the call history information for unknown callers and use this information to disallow calling activities based on select calling patterns. The call history log should be configured to perform forensics and accounting and allow the administrator to track down fraudulent calling patterns. Configure the following commands to log call activity and call history:
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_implementation_design_guide_chapter09186a00805f07a8.html#wp1077193
Logging CDR to External Servers
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/products_implementation_design_guide_chapter09186a00805f07a6.html#wp1076106
Hope this helps!
Rob
rommel-peraza Mon, 09/17/2007 - 06:26
Hi Rob,
Thank you for your answer, i?ve reading those documents this morning and I guess that the commands you mentioned make the router to "capture" the call statistics an send it to a syslog server (for example) but how can i use those logs for make a "readable" report such as allow me to control the telephone service consumption of a single branch office?
Thanks again
Rob Huffman Mon, 09/17/2007 - 06:46
  • Hall of Fame,
    Founding Member
Hi Rommel,
The parsing of this info is the tough part :( You might want to look into Cisco Partner "Stonevoice" that has a nice application for doing up these reports/graphs etc;
http://www.stonevoice.com/Products/AccountingBilling/tabid/767/Default.aspx#o
Hope this helps!
Rob
rommel-peraza Mon, 09/17/2007 - 07:35
Yes I?ve also seen Stonevoice option and other 3rd party applications, I just was hoping there were a less expensive way to do it... ja ja ... but it seems to be the only way, thanks again Rob
rommel-peraza Mon, 09/17/2007 - 10:27
Hi Rob,
I am trying to see those logs and I can?t ... I have used the dial-control-mib commands and also gw-accounting syslog and loggin A.B.C.D but I can?t see anything at the server (a laptop with Kiwi Syslog Server). What I am doing wrong?
