Help to build a SQL query in CDR
mirtenmous
I need to do a sql query that shows me calls receveid for a dial number and were transfered from another dial number in a determinate date and time.
Can anybody help me?.
benhanson
Here's my basic "everything to and from a given number" query. This is at least a starting point for you.
SELECT DATEADD([second], dateTimeOrigination - 32400, CONVERT(DATETIME, '1970-01-01 00:00:00', 102)) AS Called_At, callingPartyNumber AS Extension,
originalCalledPartyNumber, finalCalledPartyNumber, DATEADD([second], dateTimeConnect - 32400, CONVERT(DATETIME, '1970-01-01 00:00:00', 102))
AS TimeConnect, DATEADD([second], dateTimeDisconnect - 32400, CONVERT(DATETIME, '1970-01-01 00:00:00', 102)) AS Time_Disconnect, duration,
callingPartyNumberPartition, originalCalledPartyNumberPartition
FROM CallDetailRecord
WHERE (originalCalledPartyNumber = '12345678') OR
(callingPartyNumber = '12345678')
ORDER BY dateTimeOrigination DESC
pklos
Level 4
Level 4
If this call is transfered from another number you can find it by filtering on lastRedirectDn field.
regards,
pk
I think it is not a good answer for my knowledge building SQL queries.
Thanks.
benhanson
