Correctness check? 3560 Switch with interVLAN Routing
Sep 17th, 2007
I am trying to avoid using subinterfaces on my 2811 Router for the routing between my 3 VLANS (Voice, Data, Infrastructure). Would enabling ip routing on the 3560 Switch allow me to do this? Here is my proposed configuration (Can you check to make sure my static routes are configured correctly also?):
3560 switch (vlans are configured for each port and have 1 port as trunk to router):
ip routing
interface Vlan10
description Data
ip address 10.1.1.1 255.255.255.0
interface Vlan20
description Voice
ip address 10.1.2.1 255.255.255.0
interface Vlan30
description Infrastructure
ip address 10.1.3.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.1.2.2
Ony my 2811 Router:
interface FA0/0
description Connection to Switch
ip address 10.1.2.2 255.255.255.0
duplex auto
speed auto
ip route 10.1.0.0 255.255.255.0 10.1.2.1
Would these statements take care of the routing between VLANS and also for the connection to/from the internet? Thanks again for the critique!
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 09/17/2007 - 05:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Change the following
to
ip route 10.1.1.0 255.255.0.0 10.1.2.1
and the rest is fine.
Edit - your port that connects to the router should not be a trunk port. It should be in vlan 20
Jon
tomtom001 Tue, 09/18/2007 - 14:03
Thanks Jon,
I changed the port for the router connection to :
interface FastEthernet0/24
description ***Interface to Router***
switchport access vlan 20
I am able to ping the devices in vlan 20, however am unable to ping any other devices. Never tried routing on a switch before...is there a static route that I am missing?
lgijssel Mon, 09/17/2007 - 05:13
  • Red, 2250 points or more
Almost correct. I assume the proposed static was a typo? Should be something like:
ip route 10.1.0.0 255.255.252.0 10.1.2.1
To enable NAT, add networks 10.1.1 - 10.1.3 to the access-list that defines what should be natted.
regards,
Leo
tomtom001 Mon, 09/17/2007 - 05:48
Thanks Leo! Yes, the static route is something that I am still figuring out.
If I have an IPSEC VPN tunnel to another 2811 router at a remote site with the same setup (their IP ranges are 10.2.0.0 255.255.255.0 with the same VLAN structure), would the ip route command be:
This current 2811:
ip route 10.2.0.0 255.255.255.0 10.2.2.1
Remote 2811:
Appreciate the help and thank you for the patience!
