ISDN Dialer profile authenticates then disconnects
Sep 17th, 2007
I have a Cisco 3745 as follows:
2 FastEthernet interfaces
31 Serial interfaces
1 ISDN Basic Rate interface
60 terminal lines
2 Channelized E1/PRI ports
I have it configured for dial in with radius authentication for PSTN users. This works fine and all ASYNC users connect fine. However, when an ISDN user connects they authenticate fine, but the connection then drops. I have debugged ppp authentication and it seems fine. I can't find any errors.
I am sure I am missing some config somewhere. Any help you guys can give is appreciated :)
Cisco 3745 config (chopped)
hostname router1
aaa new-model
aaa group server radius groupname
server x.x.x.x auth-port 1812 acct-port 1813
aaa authentication ppp profilename group groupname
aaa authorization network default group groupname
aaa accounting delay-start
aaa accounting update newinfo periodic 5
aaa accounting exec default start-stop group groupname
aaa accounting network default start-stop group groupname
aaa session-id common
modem country mica e1-default
no ip source-route
ip cef
no ip domain lookup
multilink virtual-template 1
isdn switch-type primary-net5
isdn tei-negotiation first-call
controller E1 3/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
interface Serial3/0:15
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer pool-member 1
no snmp trap link-status
isdn incoming-voice modem
fair-queue 64 256 0
no cdp enable
ppp authentication chap profilename
ppp multilink
interface Virtual-Template1
no peer default ip address
ppp multilink
interface Dialer0
encapsulation ppp
dialer pool 1
no cdp enable
ppp ipcp dns x.x.x.x x.x.x.x
ppp multilink
interface Group-Async1
encapsulation ppp
async mode interactive
no fair-queue
ppp multilink
group-range 33 62
radius-server host x.x.x.x auth-port 1812 acct-port 1813
radius-server retransmit 2
radius-server key xxxxxx
Remote router:
interface BRI0/1
ip address xxxx
encapsulation ppp
no ip mroute-cache
isdn switch-type basic-net3
interface Dialer1
bandwidth 64
ip address negotiated
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer string xxxxxxx
dialer-group 1
compress predictor
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp multilink
Debug outputs attached.
lgijssel Tue, 09/18/2007 - 05:18
Looks like it's failing on the link compression:
Sep 17 14:29:47: BR0/1:1 LCP: I PROTREJ [Open] id 89 len 12 protocol CCP (0x80FD013500060102)
This parameter is only configured on the remote side: compress predictor
You can either configure it on both sides or remove it from both. At least you can see if it makes any difference when you play with this setting.
regards,
Leo
skelk Tue, 09/18/2007 - 05:47
Hi Leo - Thank you for your reply. I have removed this setting now and it seems to be doing the same thing... authenticates then disconnects. :(
Looking at the history on the forum - a few people have reported this issue - but I can't see any fix.
lgijssel Tue, 09/18/2007 - 05:55
The other thing I noticed was:
Sep 17 11:43:50: BR0/1:1 CHAP: Username ROUTER1 not found
While the interface is a BRI instead of PRI I think this is probably on the other end?
Can you try to add the following line to the remote router:
username router1 password
regards,
Leo
skelk Thu, 09/20/2007 - 00:53
Hi Leo,
giving this a whirl but now radius files so trying to figure out what is up there... will post results.
skelk Thu, 09/20/2007 - 02:37
Radius was failing because of the password used. This is now correct and authenticates again, but disconnects straight after :(
