required number of CCM licenses
Answered Question
Sep 17th, 2007
Dear all!
Is it necessary to buy a license for every node in CCM cluster?
We have two nodes in CCM5.1 cluster and we planned two licenses, so I'm just about to check out am I right about number of licenses?
Zoran Milenkovic
Correct Answer by Rob Huffman about 9 years 6 months ago
Hi Zoran,
You are most correct :) You require a "Node License" for each Node, so in your design 2 is the proper number;
License File Contents
The license file contains the following information:
**Number of Cisco Unified CallManager nodes that are licensed: This indicates number of Cisco Unified CallManager servers in a cluster that are licensed to the customer.
Versions of the Cisco Unified CallManager that are supported.
Number of phone units licensed: Instead of creating a separate license for each phone type, a concept of unit license is used. Each phone type corresponds to a fixed number of license units.
Note To determine the number of license unit that are required for each device, choose System > Licensing > License Unit Calculator. This window lists the number of license units required for each type of device. See the "Calculating License Units" section.
MAC address of the server, where the license file can be installed.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080633230.html#wp1049590
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 09/17/2007 - 08:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Zoran,
From this good doc;
Hope this helps!
Rob
