Add static route to ACS SE
N3t W0rK3r
Level 3
Level 3
How can I add a static route to my ACS SE appliance?
I am trying to get AAA working on a Cisco 871 that is a remote end-point of an ASA-to-871 s2s vpn. On the router I am using vlan1 as the source interface for tacacs.
My ACS server sits on my ASA's Management subnet, but the ACS' route back to the remote LAN is via its default gateway and the ASA's INSIDE interface. I need to get the ACS tacacs traffic to return via the ASA management interface.
Thanks in advance.
John
Jagdeep Gambhir
Level 10
Level 10
John,
There is no way to set a static route in the ACS appliance. The only network parameters you can set are the ip address/subnet, default gateway, and dns servers.
~JG
Please mark it resolved so other can benefit from it
Jagdeep Gambhir
Level 10
Level 10
John,
~JG
