Radio Interface Resets.
Sep 17th, 2007
we have found a specular error on the radio interface of the Access Point.
Errors on the Radiso Interface area as below.
Dot11Radio0 is up, line protocol is up
47575 output errors, 0 collisions, 4 interface resets
0 lost carrier, 0 no carrier
Please Help me up.
SRIHARI
irisrios Fri, 09/21/2007 - 10:30
  • Silver, 250 points or more
Reset indicate number of tims interface has been reset. This happens when th packet queued for transmission is not sent within specified seconds. This might be due to a cable problem on serial line or malfunctioning modem that is not supplying transmit clock signals.
srihari_rgda Fri, 09/21/2007 - 23:23
Thank you Dear,
But this problem araises on all the AP's that are in the network. so this cannot be a cable problem. What could be reason.
if the radio interfaces are reset frequently what could be the cause.
Srihari
IGBarrere Mon, 09/24/2007 - 14:17
Are all your access points operating on the same channel? It sounds like some sort of malformed packets that they may be receiving...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
