how to disable (not delete) a VPN tunnel
Sep 17th, 2007
Is there a way to disable a site-to-site VPN tunnel on an ASA 5510? I know I can delete the tunnel policies and rules, but I want to keep them in place and simply disable the tunnel temporarily.
Overall Rating: 4 (3 ratings)
bamnocadmin Mon, 09/17/2007 - 08:01
I would remove NAT statement for interesting traffic nat /(inside) 0 access-list NoNAT/.
I do not think there is an option to disable VPN.
Jon Marshall Mon, 09/17/2007 - 12:16
Hi Nick
The way i used to do it was simply to remove or change the pre-shared key, assuming you are using pre-shared keys.
If not just edit the crypto map access-list.
mfreijser Tue, 09/18/2007 - 05:04
I always place the keyword 'inactive' behind the crypto map access-list. This way no traffic is matched for the tunnel, so no tunnel is created! You can just remove the keyword inactive bij replacing the access-rule with the original rule.
Here's an example:
access-list vpntunnel extended permit ip inactive
Please rate if the post is usefull!
