How to do Call Foward All for a Hunt Pilot without Web Interface
Sep 17th, 2007
Hello we have CM 4.2 and we have a hunt pilot for the 2 receptionists.
I believe there MUST be a way, either by scripting or a workaround to setup a button to Call Foward All a Hunt Pilot - I will like to do this without depending on the computer to use the Web interface to do it.
Anybody think is possible?
pklos Mon, 09/17/2007 - 08:08
You can change it directly in CCM SQL database.
ocarmona777 Mon, 09/17/2007 - 08:29
That would still be PC Dependant. Is there a way that maybe through a "service" on the actual phone or a button that they can easily press.
pklos Mon, 09/17/2007 - 08:34
Yes, you can create XML service linked to speed dial button (but it only User Interface). so asp/php/??? script generating this service can change Forward All parameter for hunt pilot using SQL Query or AXL API.
