New with configuring BVI. I have a 1310 bridged to an older Cisco bridge on our WLAN. On a wired client machine behind this new bridge, I can ping, telnet, remote, get DHCP address successfully. I cannot ping, contact default gateway and therefore get to the internet with any clients behind this bridge. I have attached the config. Hopefully, it is something simple I am missing in the configuration.
Current configuration : 1109 bytes
version 12.4
no service pad
service password-encryption
hostname HSAGBRIDGE
enable secret xxx
no aaa new-model
resource policy
ip subnet-zero
ip name-server 10.28.1.2
dot11 ssid tsunami
authentication open
infrastructure-ssid
dot11 network-map
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid tsunami
antenna transmit right
antenna receive right
antenna gain 24
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.28.3.10 255.255.0.0
no ip route-cache
ip default-gateway 10.28.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community tsunami RO
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
