One Way Audio after 20 minutes
Sep 17th, 2007
I have a strange issue I am working with TAC on... I have a remote site, that looses its transmit audio after approx 20 minutes...
Everything works great and then all of the sudden transmit audio drops out. The phone is still transmitting packets, however my voice gateway on the other side is no longer receiving any RTP packets... We have also tested IP phone to IP phone and have the same results... Other remote sites do not have this issue...
Jeff Garner Mon, 09/17/2007 - 09:17
No, not a vpn site. Its frame relay back to the main site with two PVCs... Im have verified routing is correct, however Im going to shutdown the other PVC today and see if it goes away. There are no firewalls between the two sites...
shikamarunara Mon, 09/17/2007 - 12:00
On your routing end points, try
voice rtp send-recv
See if this works, if not, post a config of your frame relay gateways.
Jeff Garner Tue, 09/18/2007 - 06:31
We Found the issue
Cisco bug CSCsd91454
RTP calls get disconnected when cRTP enabled
Symptom: Person 'A' and 'B' speaking. At some random point during the call, person A would stop being able to hear person B, person B would still be able to hear person A and if the call was put on hold, then resumed, both would be able to speak and listen normally till this happened again. Conditions: Have seen the issue on links with 768k bandwidth Workaround: Disable cRTP
