Site-To-Site VPN between 7.1 (1) and 6.3 (5)
Sep 17th, 2007
Can someone please look at my config and tell me what's wrong with it because i can't figure it.
I have been trying to create a site to site vpn without any luck. However, i have been successfully created a vpn for my clients.
Thanks in advance!!
Jon Marshall Mon, 09/17/2007 - 23:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I can't see any Phase 1 isakmp settings in your pix 6.3 config, ie you need
1) isakmp policy
2) isakmp key
3) isakmp enable
Jon
mfreijser Tue, 09/18/2007 - 01:14
  • Bronze, 100 points or more
As said above, you are completely missing ISAKMP configuration. Try adding the following commands to your Pix with software version 6.3(5):
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp key **** address 71.4.148.xxx netmask 255.255.255.255
Notice that you should replace the **** with the same pre-shared key you configured on the PIX/ASA with software version 7.1(1)
Please rate the post if it's usefull to you!
Michael
