NAT for multiple private subnets
Sep 17th, 2007
I have an ASA5510 for internet access. On the private side, it is on the same LAN as a 2800 series router with multiple GE interfaces, running two subnets. I want to NAT both the subnets from the 2800 series to the ASA5510 using a single dynamic NAT pool.
I can configure one or the other on the the ASA, but not both it seems.
Error is "portmap translation creation failed" for either subnet.
Jon Marshall Mon, 09/17/2007 - 09:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
So does your config look something like this ?
ciscoasa(config)# sh running-config nat
nat (inside) 1 192.168.5.0 255.255.255.0
nat (inside) 1 192.168.6.0 255.255.255.0
ciscoasa(config)# sh running-config global
global (outside) 1 172.16.5.1-172.16.5.254 netmask 255.255.255.0
Jon
dhawthrone Tue, 09/18/2007 - 04:07
Here is what it looks like (IP addresses omitted)
ASA5510Primary# sho running-config nat
nat (INSIDE) 0 access-list INSIDE_nat0_outbound
nat (INSIDE) 15 10.100.1.0 255.255.255.0
nat (INSIDE) 15 172.16.1.0 255.255.255.0
nat (DMZ01) 20 10.100.2.0 255.255.255.0
ASA5510Primary# sho running-config global
global (OUTSIDE) 15 X.X.X.X-X.X.X.X netmask 255.255.255.X
global (OUTSIDE) 30 X.X.X.X-X.X.X.X netmask 255.0.0.0
global (OUTSIDE) 10 interface
global (OUTSIDE) 20 X.X.X.X netmask 255.255.255.X
When I add nat (INSIDE) 15 10.100.1.0 255.255.255.0 I start receiving the portmap translation creation failed errors.
It works fine if only one of the nat (INSIDE) statements is present though.
