Is the NM-1CE1T1-PRI the correct card for a frame circuit in a 2811 router?
Answered Question
Sep 17th, 2007
I have a 2811 router and a NM-1CE1T1-PRI card. Is this the correct card for a frame cirucit? I have the card installed but I don't see a serial interface for it. Show ver does show the card:
1 Channelized (E1 or T1)/PRI port
I'm thinking I have the wrong card. But I'm not sure.
Mike
Correct Answer by Paolo Bevilacqua about 9 years 6 months ago
It's fine. configure:
controller t1 x/y
channel-group 0 timeslots 1 24
the serial interface will appear and configure you FR in there.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Mon, 09/17/2007 - 11:06
  • Hall of Fame,
    Founding Member
controller t1 x/y
MICHAEL CICCONE Mon, 09/17/2007 - 11:11
Thanks for the help... I see the serial interface now. In you example above channgel-group 0 timeslots 1 24. I could not put in the "24" Not sure I thats a big deal or not.
Paolo Bevilacqua Mon, 09/17/2007 - 11:29
  • Hall of Fame,
    Founding Member
Ok, I missed a needed dash. Do:
interface x/0:0
shutdown
controller t1 x/0
no channel-group 0 timeslots 1
channel-group 0 timeslots 1-24
and you should be fine.
Thanks for the nice rating and good luck!
Paolo
MICHAEL CICCONE Mon, 09/17/2007 - 12:35
Paolo,
Some very stragge happen on the router. The command controller from config t is no longer there. I'm not sure what happen, any ideas?
MICHAEL CICCONE Mon, 09/17/2007 - 12:49
Paolo,
I figured out what happen. the command "card type" was missing. Not sure why. But once I put that back in the controller command was available.
Thanks again
Mike C.
