Use traffic amount as threshold via radius
Sep 17th, 2007
is it possible, to pre-set an amount of traffic for remote users, after that the connection is closed, via radius vsa? (for prepaid-cards customers, with ie. 1gb of traffic).
I was thinking about qos policy via radius attribute, but I've found only about rate limiting.
Thanks in advance,
Massimiliano
htarra Fri, 09/21/2007 - 12:47
  • Bronze, 100 points or more
I think you can do . You need the cisco-policy-up/down as you are attaching the service policies to the virtual-accessintefaces which is what those atts are doing.The following needs to be added to the radius dictionary to make this work: VENDOR Cisco 9
ATTRIBUTE Cisco-avpair 1 string Cisco
ATTRIBUTE Cisco-Policy-Up 37 string Cisco
ATTRIBUTE Cisco-Policy-Down 38 string Cisco
massimiliano.macri Mon, 09/24/2007 - 01:42
Hi, thanks for the answer
I'm not sure about how to specify the correct policy in the radius users profiles, ie this should accomplish rate limiting:
[email protected] Password = "cisco"
Service-Type = Framed,
Framed-Protocol = PPP,
Framed-MTU = 1400,
Framed-Routing = 1
Cisco-Avpair = "lcp:interface-config=rate-limit output
access-group 101 64000 16000 32000 conform-action transmit exceed-action drop",
interface Virtual-Access2
mtu 1492
ip unnumbered Loopback1
rate-limit output access-group 101 64000
I was trying to understand what are the correct strings for the quota management, so I can build a "quota profile".
Massimiliano
massimiliano.macri Mon, 09/24/2007 - 01:46
Hi, I forgot that the other half of the problem is probably create a correct policy on the device, ie (same for limiting):
policymap parent_shaping
class class-default
shape average {speed}
service-policy child_queueing
policymap child_queueing
class c1
priority Y
class c2
bandwidth X
interface ethernet 1/0
pppoe enable
service-policy output parent_shaping
I have no hints or documentation for quota limiting,
Massimiliano
