WS-C2960G-24TC-L IOS question.
Sep 17th, 2007
Hey everyone, this should be a quick once.
I was under the impression that c2960-lanbasek9-mz.122-40.SE.bin should be okay to load onto the WS-C2960G-24TC-L,
but when I tftped the file over to my switch and setup the boot sequence like so:
BOOT path-list : flash:/c2960-lanbasek9-mz.122-40.SE.bin;flash:/c2960-lanbase-mz.122-25.SEE3/c2960-lanbase-mz.122-25.SEE3.bin
It starts to load the new IOS, says it has an error loading, and starts my older version up just fine.
So...did I just not read well enough and attempt to load on an invalid image?
If not...any suggestions on how to get it to load right would be handy.
JORGE RODRIGUEZ Mon, 09/17/2007 - 10:54
James, if in doubt best is to go to software advisory and do a search by platform c2960 which will point you to right codes..if the one you downloded is the correct version delete it and tftp it again, it may have gotten currupted .
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
CCO required / under software tools pick Software advisory - the software by platform
http://www.cisco.com/public/sw-center/
Jorge
jamesmpoplar Mon, 09/17/2007 - 11:07
Well, I've reloaded the .bin a couple of times, and the verify command says that the image is good.
As far as I can tell...this SHOULD load on this switch with no issues.
glen.grant Mon, 09/17/2007 - 11:09
If you do a "dir flash: do both show up ? Looks like the old one is in a directory . Does the 2960 have enough room for 2 images ? I know the older 2950's could only hold 1 image at a time . Verify you have a complete new ios file .
jamesmpoplar Mon, 09/17/2007 - 11:18
Well, dir flash: shows them both:
32514048 bytes total (20805632 bytes free)
PASASW0007#dir flash:
Directory of flash:/
2 -rwx 1216 Feb 28 1993 17:01:07 -07:00 vlan.dat
3 -rwx 27 Sep 17 2007 11:08:05 -06:00 private-config.text
4 -rwx 3991596 Sep 17 2007 13:02:45 -06:00 c2960-lanbasek9-mz.122-40.SE.bin
5 drwx 192 Feb 28 1993 17:06:31 -07:00 c2960-lanbase-mz.122-25.SEE3
621 -rwx 4165 Sep 17 2007 11:08:05 -06:00 config.text
And they are both the same size, from the UNIX TFTP server to the flash itself.
The .bin file should be all I need. It appears the directory is there mostly because the HTTP is enabled on the old image.
It gets about this far:
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:/c2960-lanbasek9-mz.122-40.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Error loading "flash:/c2960-lanbasek9-mz.122-40.SE.bin"
jamesmpoplar Mon, 09/17/2007 - 11:49
Ha!
The problem was that the version on the tftp server was actually a different version of IOS, but renamed funny when it was sftped to the tftp server.
Therefor it would verify just fine. :) Works fine now. Thanks for all the possible solutions.
