Problems installing CCM 5.1
Sep 17th, 2007
After finishing the preinstallation I got the following error message:
Cisco Unified CallManager
Critical Error
The installation has encountered a unrecoverable
internal error. For further assistance report the
following information to your support provider.
install PostInstall
/usr/local/cm/ /usr/local/cm/
/common/log/install/install.log" exited with errors (1)
The system will now halt.
When I reboot the system I have the following error:
"INSTALLATION FAILED - restart installation to recover from failure"
And then, if I reboot the system with the Install DVD or Recovery DVD it stops working (no keyboard input and no video output).
What can I do?
Tommer Catlin Mon, 09/17/2007 - 14:22
Sometimes the install does not go through. You are better off just putting in the DVD and start over. Takes another hour or so and it will install.
victorgarciaternero Mon, 09/17/2007 - 23:18
Thanks, but if I boot from dvd the system looks like it doesn?t respond to any input, and the monitor goes off. Is it normal? I simply boot inserting the dvd into the dvd unit, and I press F12 to go into the boot menu to select boot from dvd. Is it the correct procedure to boot from dvd?
tboynton Wed, 09/19/2007 - 04:39
Yes, the DVD should boot to an install screen. A while back Cisco had sent out a batch of bad media. Just a thought.
It sounds like you are upgrading from some other version to 5.X. Are you using the same ip address on the 5.x server as you are on your other server?
