Installing VPN Client 5.0.01.0600 on Vista
Sep 17th, 2007
Hi There,
I'm having some problems with the VPN client 5.0.01.0600 for Windows Vista.
I've installed the client but when trying to connect I receive the following error;
"Reason 421: The remote peer is not responding"
This to me would suggest an issue with our 2600 series router however ive tried connecting to it using two other laptops running Windows XP (from the same internet connection) and theyve connected fine with no issues.
Ive attached my logs from when I try to connect.
Any ideas would be much appreciated!
