Warning message
Allow dial up access to a 1750
Sep 17th, 2007
Hi all. I have a 1750 router running IOS 12.1(3)XT2.
I need to allow at least 2 concurrent analog connections to connect and pass the information to a radius server. I have the part about the radius server figured out, but I need to know if anyone has been able to get a WIC-2AM to work for this scenario.
ljohns Thu, 10/18/2007 - 20:09
I have made it work with external modems but not with the AM modules but i think it can. You can configure each async interface and test to make sure you can connect and pass traffic. If you want them to look like one interface you will then have to configure a multilink interface and put both of the async interfaces in it.
Here is a doc that shows how to do Async Multilink PPP.
http://www.cisco.com/en/US/partner/tech/tk801/tk36/technologies_configuration_example09186a008009455c.shtml
