Failed to start Kadis
Sep 17th, 2007
Does anybody know what following log message is related to?
"Failed to start Kadis. Status -10"
Appears shortly after bootup, once.
7204VXR/NPE-2G with EIGRP, BFD, some QoS
Alex
sgelli Mon, 09/17/2007 - 21:27
  • Cisco Employee,
What is the IOS version of IOS?
a.gesse Tue, 09/18/2007 - 08:26
12.2(4)XD8, Advance Security.
I think it may be related to BFD. not sure though
Alex
sgelli Tue, 09/18/2007 - 09:39
  • Cisco Employee,
Yes...it is BFD related and the problem is with BFD support on NPE-G2. This problem is fixed in 12.4(16.5)T or higher. This version is not available on CCO for you to download yet. You can request a TAC engineer to post an Engineering Special with the fix if you would like to test.
sgelli Tue, 09/18/2007 - 09:41
  • Cisco Employee,
a.gesse Tue, 09/18/2007 - 10:35
Thank you for the info!
I am currently on (15)T1 version and you are saying that it is not going to work until (16.5)T.
I see some bfd behavior that doesn't correlate to docs, and it may be due to above.
If this technology is such hot, may be it is not a good idea to use it under EIGRP for WAN failures detection over ISP's switched Ethernet links? We are cutting over next month.
Reduced timers?
Alex
