Trusting DSCP in a Cat4500 on routed ports.
Sep 17th, 2007
We have a 4503 with Sup II+ running IOS 12.2(37)SG. Our Avaya PBX medpros and clans are connected to the WS-X4548-GB-RJ45 blade. Two ports of that same blade are the uplinks to two 6506 distribution switches.
The uplink ports are L3, and the ports connected to the medpros and clans are of course L2.
Here is an example of the QOS commands and an uplink port config and a medpro connected port config:
policy-map autoqos-voip-policy
class class-default
dbl
qos
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 5 to dscp 46
interface GigabitEthernet1/1
description GHQ-RS6506A G3/2 E215
no switchport
ip address xxx.xxx.xxx.xxx 255.255.255.252
interface GigabitEthernet2/37
description Medpro #1
switchport access vlan 910
switchport mode access
speed 100
duplex full
qos trust dscp
auto qos voip trust
tx-queue 3
priority high
no cdp enable
spanning-tree portfast
service-policy output autoqos-voip-policy
interface Vlan910
ip address xxx.xxx.18.1 255.255.255.128
The Avaya PBX marks the voice packets with DSCP=46 and the control packets with DSCP=24.
To insure that the uplinks don't zero out the markings, to trust them, do I need to add a voip trust statement to the G1/1 config even though it is an L3 interface?
Anonymous (not verified) Fri, 09/21/2007 - 13:52
If you are concerned with setting up a port on this 4507R tosupport a Cisco IP phone, then I recommend using the 'auto qos voip cisco-phone' interface command,after enabling 'qos' globally on the switch. This will do two things: one it will set up the port to
'trust cos' and it will set up the priority for the 3rd tx-queue on the interface. This will prioritize packets being transmitted to the phone. In addition, if you have configured a vlan other than vlan 1 to be the voice vlan you should configure 'switchport voice vlan ' under the inteface.
