Assistance with Fax Server Solution
Sep 17th, 2007
My company is wanting to implement a Cisco Fax Server Solution, Rightfax 9.3, to reduce costs. We are running Cisco VoIP and a network that spans 12 buildings. What do we need to have in place and/or need to purchase to impliment this solution or is there somewhere specific that we can learn how to do this?
Overall Rating: 5 (1 ratings)
sjones226 Mon, 10/01/2007 - 12:27
Do you have any experience installing Right Fax? Can you recommend any resources for installation, someone who's been there, done that?
probert100 Fri, 10/05/2007 - 10:57
Have you looked at XMedius?
XMedius is a very nice solution, acts as a H.323 gateway so you can leverage what you already have in place. You may not even have to add
PRI or T1 line.
Hope this helps.
RightFax is not the right solution. There is much better out there... Look at XMediusFAX from Sagem-Interstar. It is a proven robust solution that truly leverages the Cisco VoIP infrastructure, does not require any fax boards, it's all software and uses T.38 with Voice gateways and CCM. Take a look at the Partner Solution catalog. XMediusFAX is a certified CTDP solution.
sjones226 Tue, 10/23/2007 - 19:54
Thank you for your response. We have looked into this offering as well, yet still seeking to deploy the Cisco-branded solution.
Well, I'm sorry to hear that :-) You will have quite a challenge with the RightFax product to make it work reliably accross multiple locations on a Cisco VoIP network. The solution requires expensive fax boards, it is out priced and will be a nightmare, especially V9.3. you may want to re-consider your options. You should talk to other engineers in the Cisco circles to get a better insight. Good luck any way...
