Problems with configuring netflow
I'm trying to setup up netflow to export to a collection server, but I don't see any traffic coming from the router in question to the collection server, nor do I see the flow information on the router itself when i use show ip flow cache. Any ideas on what I might be doing wrong? I'm using the defaults for this initial configuration.
avmabe Mon, 09/17/2007 - 12:47
What kind of device?
What is the actual config on the device?
Jan Nejman Tue, 09/18/2007 - 02:40
set the following:
on interfaces serial0/0/0, GigabitEthernet0/0, GigabitEthernet0/1 set: ip flow ingress
or ip flow route-cache
I think that it helps. Set also flow export timers: ip flow-cache timeout active + inactive
I recommend set inactive to 30 sec and active to 1-3 minute...
Kind regards,
Jan Nejman
Caligare Co.
