Vista Buisness VPN Error: 442
Sep 17th, 2007
I have seen a number of posts and searched a number of sites looking for a solution for the 442 error.
I am using Version as this is the only supported (and downloadable) version by my network admins.
At least 90% of the time, I type in my password and I receive the following:
Error 442: Failed to enable virtual device.
What can be done about this?
mfreijser Tue, 09/18/2007 - 01:42
There are numerous things that you can do to try to solve the problem. There is, for as far as i know, no real solution.
You can try one (or more) of the following things:
- Multiple NICs enabled:
Disable all NICs you do not have in use. If you have a wireless-NIC and a ethernet-NIC, and you're only using the wireles; disable the ethernet-NIC.
- Manually enable the VPN Adapter:
Manually enable the VPN-Adapter in 'Network Connections'
- Reboot!
Reboot your laptop
- Fix the VPN Adapter
Open Network and Sharing Center
Open Network Connection Manager
Enable the virtual adapter (Cisco VPN Adapter)
Right-click on it and select Diagnose
Select Fix
- Run the following from 'cmd':
reg add HKLM\System\CurrentControlSet\Services\Tcpip\Parameters /v ArpRetryCount /t REG_DWORD /d 0 /f
Reboot after this
I hope that one of these will solve your problem, but sometimes it's just a matter luck.
Please rate if you find the post usefull!
Msilverman77 Tue, 09/18/2007 - 05:20
Thanks, I am aware of these steps.
Is this a Cisco bug? or a Vista bug?
Even with the "random" fix methods, this is a major inconvenience.
mfreijser Tue, 09/18/2007 - 05:41
This is actually a Cisco bug, it's solved in newer versions of the VPN Client.
The problem with your VPN Client is that version is a Beta version for Windows Vista, and as we all know; Beta's have bugs!
I think it's advisable for your network administrators that they start supporting more stable versions of the VPN Client!
Please rate if the post is usefull!
