IPCC Express Enhanced
Sep 17th, 2007
My company is deciding which version of IPCC should buy and personally I have the following question:
Does the Enhanced version allows you to create and edit prompts?Is it the prompt editor included in the software?
joluc_denmark Wed, 09/19/2007 - 00:09
Yes, you can record/delete/play prompts with the Enhanced version also.
Recording requires a script that you create with the editor. There are samples available for download.
rgds
johnny
rafaelgarcia Wed, 09/19/2007 - 05:29
Does the Editor comes as part of the Enhanced Version?
rafaelgarcia Wed, 09/19/2007 - 06:06
Abdulbaseer Mohammed Wed, 09/19/2007 - 21:49
  • Silver, 250 points or more
Not sure if I understand what you are asking about the prompts itself or just way to input modified prompts into system.
Here is a list of comaparison for all versions.
http://cisco.com/en/US/products/sw/custcosw/ps1846/products_data_sheet09186a008019ade0.html
You pretty much can do same thing with all versions regarding prompts the premium is used for CTI pop ups, data dips etc.
Baseer.
