Cisco 1760 - Can it take (2) T1-WIC's?
Answered Question
Sep 17th, 2007
I see in the data sheet that my 1760 can take a variety of WIC's. I need to expand my data pipe from 1.5Mb to 3.0Mb and was wondering if the 1760 can accomodate (2) T1-WIC's or a WIC with (2) integrated T1 BRI interfaces (I believe Cisco makes such a WIC)?
Correct Answer by paolo bevilacqua about 9 years 8 months ago
Yes, it can. Note the '2 x T1 BRI' is actually called VWIC-2MFT-T1, or VWIC-2MFT-T1E1.
Nothing to do with BRI that is something else.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Mon, 09/17/2007 - 13:09
  • Hall of Fame,
    Founding Member
girlgeeknflorida Fri, 09/21/2007 - 08:23
Thanks so much! I appreciate your support. I will have to get another WIC-1DSU-T1-V2, as the VWIC-1MFT-T1 WIC will not work in a 1760, only Cisco 2600, 2800, 3600, 3700 and Cisco 3800 series. Thanks again!
