Upgrading Cisco Agent Desktop with Custom Administrative Rights
We are in the process of upgrading IPCC Express from 4.0.4 to 4.0.5. The Cisco Agent Desktop upgrade requires Administrative Rights to the Local PC in order for the Desktop upgrade to be successful. Is there a way to just grant rights to the particular folders and\or registry keys that need to be updated without giving the End Users full Desktop Administrative rights? If so, what folders/registry permissions need to be assigned?
Abdulbaseer Mohammed Tue, 09/18/2007 - 21:41
you just need this while installation. If not then you have to grant access to cisco directory and windows directory.
That is just guess.
mwteixeira Wed, 09/19/2007 - 13:12
I am not sure if I would recommend this. I have been battling reserved states, transfer failures, and agent state changes since I implemented this. However, if you want to try it , here is how I did it:
I gave modify access to the following folders and subfolders:
-%Program Files%\Cisco
-%Program Files%\Common Files
-%Program Files%\InstallShield Installation Information
I gave modify access to the following registry keys and subkeys where noted.
Key only-HKey_Local_Machine\Software
Key/SubKeys-HKey_Local_Machine\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
Also see Cisco Document ID: 71466.
That document contains how to manually uninstall cisco agent software suite. There may be a time that Cisco Agent Updates may need to modify those Registry/Files.
I used Sysinternal tools called regmon and filemon to find where I needed to give modify access.
If anyone implements this let me know how it works for you.
I am running Cisco CRS 4.0.5 SR1
