Adding or removing WIC/VWIC
Answered Question
Sep 17th, 2007
Greetings,
This should be a quick question.
Can I remove a VWIC and replace it with a WIC without having to power down the router?
Correct Answer by dgahm about 9 years 9 months ago
No, you must power it down. Even larger routers like 3800 or 3660s that support hotswapping of NMs require a power down for VWICs and WICs.
Please rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
dgahm Mon, 09/17/2007 - 14:56
  • Blue, 1500 points or more
dgahm Mon, 09/17/2007 - 15:12
Rick,
The rating and the check mark says it all. You are very welcome.
Regards, Dave
