Line vty
Sep 17th, 2007
Hey Everyone,
I wish to remove the following:
line con 0
exec-timeout 0 0
line vty 0 4
login local
line vty 5 14
login local
line vty 15
no login
But I am getting this error message when I issue a "no line vty " command
% Can't delete last 16 VTY lines
My aim is to have only - line vty 0 15.
Any ideas anyone?
Cheers,
Mark
spremkumar Tue, 09/18/2007 - 23:13
  • Red, 2250 points or more
hi mark
can you try configuring line vty 0 15 and configure the required parameters under the same ?
do make sure that your on console while doing this ..
regds
cthakore Wed, 02/10/2016 - 08:40
I would like to peel off vty 15 and set it for login local.  IS this possible ?  Currently not allowing me to do it.  I see that the above user has it set up where vty 15 is separated like I need.
