IP phone connected through VPN tunnel but no dial tone
Sep 17th, 2007
The site to site vpn connection is established between the ASA 5510 and ASA 5505. I can see the traffic going on between the IP phone and its server. However, the phone has no dial tone. I ping the phone's IP address within the tunnel but receive only 80% echo. Does anyone know what goes wrong? Thank you!
rhugo Wed, 09/19/2007 - 10:00
  • Bronze, 100 points or more
It's dropping packets or streaming them out of order, so it sounds like either a routing issue or the version of ASA SW you are running? Check routing of packets by attaching a sniffer on the back of the phone on the other side of the tunnel and do a packet capture to see what's going on?
davidwu2007 Wed, 09/19/2007 - 10:45
Thanks for your reply.
We found the problem yesterday. It was the VPN
tunnel in which one side was using IP protocol while the other side was using TCP protocol.
