Changing CAT OS to IOS
Sep 17th, 2007
I am using an 2948G-L3 and its current system is using a CAT OS and I want to change it to IOS version. Does someone have a procedures or links that will guide me on this process? Thanks
ankbhasi Mon, 09/17/2007 - 23:15
Hi Jaime,
2948G-L3 only runs IOS and never supports CATOS. I believe you have 2948G only which only supports CATOS and cannot be upgraded or converted to IOS.
Ankur
*Pls rate all helpfull post
nourisonrugs Mon, 09/17/2007 - 23:41
Oh yes, it is a 2948G,anyway, do you have any documents on how do I start configuring the basic configurations. LIke the IP, default gw, passwords and so on...
