2 Mbps Conectivity
Sep 18th, 2007
Hi All,
we have taken a lease line of 2Mbps for connecting our Two offices. One side there is ethernet connectivity and one side is V.35 connectivity.
My Queries are:
1. Which router to use as for v.35 modem?
2. When the link is up i need to run Erp between both sides. I mean i am totally unaware of this concept. So after link is up i will be able to view all my remote PC,s as they or into lan or like what?
I mean how i will be accessing computers on one site from other?
How to share folders and run ERP software ?
Please help to get this through
Parvesh
Anand Narayana Tue, 09/18/2007 - 00:49
  • Silver, 250 points or more
Answer for ur question # 1.
Cisco 1800 series with WIC-1T wud satisfy this.
Answer for ur question #2
you have mentioned already the link is UP on the other end office(Office-A) which is ethernet connectivity, so what u need to is once after connecting the router with the above mentioned on the other side of your office(Office-B), you will be able to reach the Office-A PC's.
sharing is same like how you share the PC's locally on LAN.
eg. \\\
parveshchahal Wed, 09/19/2007 - 00:16
Dear Anand,
Thanks for replying. So when my line goes up my both the offices will be connected as they are in lan. i donot require any proxy or anything. No Live IP are required. is 1841 good option to go with? Secondly i need to configure the router Please guide me the steps how do go for complete setup of that router.
Parvesh Chahal
gaurav_thapar79 Wed, 09/19/2007 - 02:12
As per ur post, i can conclude that :
1. You want ethernet termination at Office A
2. You want V.35 termination at Office B.
3. PC folder sharing etc over this E1 ckt.
With above scenario,its not feasible to have ethernet & v.35 stuff. You can not achieve this case. V.35 serial transmission and ethernet transmission are different altogather.
3. Both side LANs can be connected on private IP series like 172.16.0.0/16 etc and routing can be done on router & L3 switches.
madickerson Wed, 09/19/2007 - 08:39
Pavesh,
I'm not a guru or anything, but if I were in your shoes, I'd make the connection from the v.35 interface to a server or other winndows box, with Dial Up Networking and IP installed. I'd open up the v.35 interface just like a modem... Then let windows set up the rest.. Using the Network setup wizard.. AFTER the v.35 interface is working.. (if you hook up a windows box, and it can see the remote office, then you're almost there..)
