Port Forwarding
Sep 18th, 2007
Hi there!
We are trying to configure a pix firewall 506e to redirect outside traffic to an inside machine.
We're using the following commands:
static (inside,outside) tcp 82.173.121.53 1417 192.168.10.137 1417 netmask 255.255.255.255
static (inside,outside) tcp 82.173.121.53 1418 192.168.10.137 1418 netmask 255.255.255.255
static (inside,outside) tcp 82.173.121.53 1419 192.168.10.137 1419 netmask 255.255.255.255
static (inside,outside) tcp 82.173.121.53 1420 192.168.10.137 1420 netmask 255.255.255.255
static (inside,outside) udp 82.173.121.53 407 192.168.10.137 407 netmask 255.255.255.255
access-list outside-inbound permit tcp any interface outside eq 1417
access-list outside-inbound permit tcp any interface outside eq 1418
access-list outside-inbound permit tcp any interface outside eq 1419
access-list outside-inbound permit tcp any interface outside eq 1420
access-list outside-inbound permit udp any interface outside eq 407
access-group outside-inbound in interface outside
We can see received packets on the hit count of the access list but only udp and we can't connect anyway.
access-list outside-inbound line 1 permit tcp any interface outside eq 1417 (hitcnt=0)
access-list outside-inbound line 2 permit tcp any interface outside eq 1418 (hitcnt=0)
access-list outside-inbound line 3 permit tcp any interface outside eq 1419 (hitcnt=0)
access-list outside-inbound line 4 permit tcp any interface outside eq 1420 (hitcnt=0)
access-list outside-inbound line 5 permit udp any interface outside eq 407 (hitcnt=1)
David
rajbhatt Tue, 09/18/2007 - 03:51
Please paste the relevant part of the config that would include :
inside access lists , nat and the global statement.
Raj
yupinho Wed, 09/19/2007 - 02:49
hello Raj
here are all the acl?s
access-list inside_access_in permit ip 192.168.10.0 255.255.255.0 any
access-list inside_access_in permit ip 192.168.20.0 255.255.255.0 any
access-list inside_access_in permit ip 192.168.40.0 255.255.255.0 any
access-list inside_outbound_nat0_acl permit ip 192.168.10.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.10.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.20.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.40.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list outside_cryptomap_100 permit ip host mvxapp host 10.23.125.185
access-list acl_intentia_ipsec permit ip 10.23.125.184 255.255.255.248 host intentia-host
access-list static-intentia-srv1 permit ip host mvxapp host intentia-host
access-list static-intentia-srv2 permit ip host 192.168.10.12 host intentia-host
access-list nat-intentia-srv1 permit ip host mvxapp host intentia-host
access-list nat-intentia-srv2 permit ip host 192.168.10.12 host intentia-host
access-list split-labicer-admin permit ip 192.168.10.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list split-labicer-admin permit ip 192.168.20.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list acl_valorceram_ipsec permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list acl_valorceram_ipsec permit ip 192.168.40.0 255.255.255.0 192.168.50.0 255.255.255.0
here are the nat and global statments
global (outside) 5 10.23.125.185
global (outside) 6 10.23.125.186
global (outside) 10 interface
global (outside) 7 10.23.125.187
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 5 access-list nat-intentia-srv1 0 0
nat (inside) 6 access-list nat-intentia-srv2 0 0
nat (inside) 10 192.168.10.0 255.255.255.0 0 0
