DUCS cLient
Sep 18th, 2007
hi ,
i install DUCS client and when i try to open a voice mail i receive the following error : (ducs client for domino is not installed ) ,
thanks
navinger Tue, 09/18/2007 - 09:53
Go into Add/Remove programs and uninstall the DUC csClient. Then re-run the DUC csClient installation. Make sure that you check the box to modify the user's mail file. The box is not checked by default.
Nancy
idrissimehdi Tue, 09/18/2007 - 15:00
hi nancy
thanks i solved my problem by add 3 lignes in the notes.ini files
ExtMgr_Addins=ucclient
UCVersion=1.2.3
UCLogLevel=1
