LOAD BALANCING TRAFFIC THE VOICE
Sep 18th, 2007
Hi all,
I need take the load balance between link of different speed and I am facing some problem as:
In these liks we have voice and data traffic running with OSPF. I need take the load balance guaranteeing that the voice traffic it will pass through the main link.
Below is the configuration:
R5(config)#
track 1 interface Serial0/0.1 line-protocol
interface Ethernet0/0
glbp 1 ip 10.100.100.1
glbp 1 priority 252
glbp 1 preempt
glbp 1 weighting 252 lower 30 upper 100
glbp 1 load-balancing weighted
glbp 1 weighting track 1 decrement 230
R6(config)#
glbp 1 priority 18
glbp 1 weighting 18 lower 10 upper 15
glbp 1 weighting track 1 decrement 10
How could I take the load balance between voice and data, taking with the voice traffic it will be forwarding by main link?
Joseph W. Doherty Tue, 09/18/2007 - 10:07
One method would be use PBR to direct your voice traffic to your preferred path.
leandro.candido Tue, 09/18/2007 - 13:10
How could I takes this?
The PBR direct the voice traffic through of source, destintation, match in voice traffic...???
Can you give example, please?
leandro.candido Wed, 09/19/2007 - 07:22
Thanks for help!
The your suggestion it working!!!
I created the PBR directing the source traffic for destination that I wish.
