LMS3.0 100% config fetch/archive failure
Sep 18th, 2007
I am recieving an error message for any device that I try to collect or archive a config on. I have tried to collect a single config by itself without any success.
The error is telling me to increase my fetch settings which do not work or change anything.
I did turn on the debug on and listed below is a sample of the results. I did not inlcude all the lines because they were all the same.
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getResultFromQuery,2838,Query: select DCR_ID from DM_Dev_State where NetworkElementID = '83'
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRId,1082,dev id: 83 dcr id : 83
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getAPIExtraInfo,2753,InheritableThreadLocal value not set: Setting it
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,initAPIXtraInfo,2514, Source context set to: vhamwvnms3/10.40.106.57__DCRWrapperAPIs__4.0
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,initAPIXtraInfo,2537, Security context set to: admin
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDisplayNameForDev,849,dev id: 83Disp name : mwv5001a106sw01
[ Fri Sep 07 13:13:52 EDT 2007 ],DEBUG,[Thread-3],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,triggerConfigFetch,40,Config fetch request received
[ Fri Sep 07 13:13:57 EDT 2007 ],DEBUG,[Thread-111],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,913,Total devices due for reqId = 1189185232687 is 1
[ Fri Sep 07 14:10:03 EDT 2007 ],DEBUG,[Thread-5],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,getStatusOfRequest,913,Total devices due for reqId = 1189185232687 is 1
Thanks for the help.
Jason
David Stanford Tue, 09/18/2007 - 05:10
This debug output doesn't really show much. What is the actual error you are receiving when trying to archive a devices config? If you set it up for one device, what error does it show in the job results?
vhamwvbarnaj Tue, 09/18/2007 - 05:17
Thanks for the quick response, the error is posted below. Could there be a rights issue on the server and writing to files? A little history on the problem and when it started.
We had alot of data in ciscoworks that was old, and out dated due to the server not being managed. I ran the following commands to restore the databases to original form therefore allowing the system to re-discover all the devices.
"net stop crmdmgtd
1. NMSROOT\bin\perl dbRestoreOrig.pl dsn=rmeng dmprefix=RME
2. NMSROOT\bin\perl dbRestoreOrig.pl dsn=ani dmprefix=ANI
3. NMSROOT\bin\perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
4. NMSROOT\bin\perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
5. NMSROOT\bin\perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
Clear CMF DB last:
6. NMSROOT\bin\perl dbRestoreOrig.pl dsn=cmf dmprefix=Cmf
net start crmdmgtd"
Error:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the
option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
vhamwvbarnaj Tue, 09/18/2007 - 08:57
Ok I resolved half of the problem. It did look like rights were an issue.
I am now getting the following error, and my current software versions are
LMS3.0
CS3.1
RME4.1.0
CM0012: Unable to create new version on archive $1 Action: Check if disk space is available and directory has required permissions
